I cant acces to my sansa clip+ 4gb when i plug it with usb, i formatt it, i reset it, tried MTP and MSC mode but it still the same, got a message from windows xp who cant reconize my device
If possible try a different cable and/or another machine. What os are you using, must be winxp or later, Linux or Mac (both MSC mode). Not sure what os needed for those but I suspect that won’t be a problem.
i’m gonna try with an another cable and on a laptop with seven
ok i tried with another cable and on a laptop with seven, the probleme is the same ![]()
i’v uninstalled the USB device and then when i plugged it back, it work!
