Upgraded my computer’s OS and attached the Fuze with USB auto detect mode. The
fuze hung, I believe the screen said connected and then switched to say writing but
it never quit writing. I finally gave up and unplugged the Fuze or shut down the compute
(can’t remember which.) After removing the fuze it was still turned on and hung –
completely unresponsive. After a reset, the Fuze worked normally but reattaching it to a
computer causes it to hang and all I can do is remove it and do a reset.
Attaching in MSC mode works normally so the unit is still functional, but if I switch
back to auto detect mode the problem is still there. Previously I had used auto detect
mode with no problem.
Any ideas how I can get the unit to work again in auto detect mode? I’ve tried reinstalling
the firmware, v01.02.31A, but nothing changed. Switching to a different computer does
not help even though I can attach a different fuze to that machine using auto detect mode.
Problem occured after upgrading OS to Ubuntu to 10.04.
