Can’t access Secure Access Vault
I created a SanDiskSecureAccess Vault on a Sandisk USB stick.
I now can’t access the secure folder: the Sandisk Private Access app can’t see the folder. It does find another folder on the stick that I had used as a test folder which has been named “PrivateAccess Vault”. That folder just has one small file in it.
The folder I’m trying to access is a different one called “SanDiskSecureAccess Vault” and it has 4GB of data that I can’t access. The Sandisk secure file browser can’t detect the folder and I have no way of pointing the secure browser at the folder.
Please can somebody help because I did everything correctly and now can’t access valuable data.
Hi @Retty,
Please contact the SD Technical Support team for the best assistance and troubleshooting:
Hi. Was your problem fixed? I’m having trouble too with my ixpand flash drive on the private access vault.
Yeah, Im on the same boat here. Any Fixes?
Use a legacy 32 bit version of macOS - Mojave - in a virtual machine (VMware Fusion Free). Then the file will load but there may still be other problems.
