I had a big issue. Appearantly, napster wanted to max out the space on the Fuze. So it did. When I turned it on a couple of hours later, it gave me a message about how there was no room for a Music DB.
I went to move some songs to the SD card, but I found that Windows no longer saw the device as a device. It saw it as a drive.
I was screwed. Just playing around, I turned HOLD on, then unplugged while holding down rewind. It complained about no room, but proceeded to normal operation. Once it synched it’s media. I was able to get to the USB mode settings and put it to MTP.
My question is why/how it got into MSC, and why did it do this at the same time as it thought it ran out of room?
Try formatting the player using your computer while the player is on MSC mode.
MSC mode:
Turn off the player
Lock the player
Press and hold left button while plugging in
Go to “my computer”
Right click drive for your Fuze, format the drive
After that, update the Firmware of the player.
If these will not work…return it to the place of purchase or better yet call 1-866-SANDISK…(1-866-7263475)
Dont return it yet, there are more things you can try. Also remember after formatting in windows to use the Fuze on board format function to get the fuze into the right configuration.
