we are very interested in acquiring a “My Book Live” drive, but we have a question about WD SmartWare softaware. If this software does a backup every day, backups are made only on files that have changes, or all files selected are backed up?
I hope you can help us with this question.
Thanks in advance.
Best regards.
Hello, by default Smartware is a continuous backup program, once you start the backup, Smartware will be looking for any new files that you add to your computer. You can also manually schedule the backup time and also select the folder that you would like to backup.
For more information you can check the Smartware manual.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705057.pdf
