I’m using WD Smartware. How do I check the auto backup settings, if I wish to change how often I want to back up my computer?.
If the WD SmartWare is installed, it will operate locally on your system and continuously monitor in the background for new files that are created so they can be backed up on your drive. This is the nature of an automatic and continuous backup application.
Can I see the display as to how often it backs up?.
It is ALWAYS backing up unless you select the option to back up only when your computer is idle.
