I use Audible and it doesn’t put books in the Audible folder or the Podcast folder, but puts it in the Music folder. I have about 20 books on the device, but only about 5 full books and various parts of a couple others show up in the list.
I tried manually moving the files from Music to Podcast, but it won’t let me.
I’m thoroughly disappointed in the piece of ■■■■ and this is just one more frustration with it.
I’ve never used Audible so I’m shooting from the hip here but, can you not tell the Audible software where the “destiniation folder” is, in other words where you want it to transfer the audio book files? It might be under Settings and/or Advanced.
Other audiobooks (DRM free or Overdrive) go straight into the Fuze’s Podcasts folder, not the Audiobook folder, then you get a new top-level Books folder which contains your audiobooks.
The question is, do audibles go in the Audible folder or the Podcasts folder. I’ve never used audibles either, but I’m sure I read somewhere on here that they should go in the Audible folder…
