I have a new SanDisk mp3 player. Can I download aif files from my computer to the SanDisk?
Hi @CharlieRan,
It is possible to download AIF files from your computer to a SanDisk MP3 player, but it will depend on the specific model of the MP3 player and its capabilities. Some SanDisk MP3 players may not support the AIF file format, in which case you will not be able to play AIF files on the device.
To transfer AIF files to your SanDisk MP3 player, you will need to connect the device to your computer using a USB cable and transfer the files using a file manager or media player software. If the SanDisk MP3 player does not support AIF files, you may need to convert the files to a compatible audio format (such as MP3 or WAV) before transferring them to the device.
