@nonipoduser22 wrote:
I was just wondering if there was a chance for a future firmware update to intergrate the SD memory and onboard memory of songs. Also for the songs to play by album order and not alphabet order, and for there to be a more than 2000 song limit.
Â
Combining the internal and external memories is a hardware limitation so no, that ain’t gonna happen.
Ironically, when the Sport first came out, it had a 4,000 track limit for the internal and 4,000 limit for the card. When attempting to fix some bugs in the first firmware update though, extra memory space was needed, so the database was cut in half. So no, that’s not going to change either.
As far as playing in album order, if you edit the ID3 tags of the files and put the track number at the beginning of the title, it should play in the desired order (Example: 05 - Lucy In The Sky With Diamonds)
