i tried regedit, spybot, malwarebytes, unlocker, acronis secureclean…nothing can crack the write protection. i have a 8gb cruiser fit.
please help
please help
i have the same problem… its no use… i tried on Win7, XP and Linux… all failed.
There are actually steps n the KB regarding this. Hope it works for you guys.
To which a link would be helpful.
Basically guys, return it to the store where you bought it and have them replace it.
write protection is comman problem so don’t take it serious. Check this
