As the title implies, is there any way to get album art to show up with FLAC files?
If you’re using MSC mode (which, oddly, is the non-Microsoft mode), as opposed to MTP, you can put a JPEG format file of size 176x176 in the folder with the FLAC files and the Fuze will show it. Name the file folder.jpg.
BTW, the folder.jpg method works with all file types. Embedded art is only supported for mp3 right now.
