Anyone know where I can get a replacement USB to Clip cable. I’m concerned the molded connector in the middle of
the existing cable may cantain components that are neccessary for a proper connection.
Thanks, Mike
Thanks, Mike
The molded device in the middle of the Clip’s pigtail is most likely an RF suppressing ferrite cylinder. The Clip is quite happy with longer Mini-USB cables available for digital cameras, and other devices.
Perhaps you could call 1-866-SANDISK and inquire about spares? They may be able to point you to a source, otherwise, I have tested several standard “camera” cables, with success.
Bob :smileyvery-happy:
Thanks, Bob
