A Way To Increase Volume
Thanks for the replies guys.
Marvin, that’s the way I’ve got it set up and it’s adequate.  Overall I’m happy with it.
It’s for a workout and I can hear the tunes to that’s the point I guess.   I’m like a kid in
that I’m always looking of more volume.   That’s why my hearing ■■■■■ to begin with…lol.
Regards,
Len
im sending my one back as i carnt get the volume above low …
its ■■■■ i carnt here owt …what good’s that  :(
You’ve probably set your Region to Europe which applies a gov’t.-mandated volume restriction. Luckily, there is a way around it. Reset your Factory Defaults and it will ask you again to choose your Region , This time, select Rest of World (or North America). You will now have your High volume option back in the Settings menu.
Don’t forget the volume rocker switch on the side to raise or lower the volume. These things will blast your ears out, so be careful! :wink:
ok mate ? how do i do a reset lol…im still trying to work out how i change from 1 alburn to the next…
is there a way to tell idf its set already …if not how do i do the reset .
thanks for the help…the sound is realy good just to low for me as it is :frowning:
ok it say i the book the default setting of the maximum volume of the player is set to 80db…
for certain use of this mp3 player with replacement headphones…it is possible to ( override this standard setting of 80db…
but i carnt find how you do it lol ?.. i tryed holding down the on/off button for 15 sec’s but that dident do owt it just come back on …
i carnt even find settings on the player nor the radio for that matter :(
thanks again for help
ok think ive dune it …
i have updated to what i think is the latest FW and now its ok :)…
volume is blasting out lol
is the FW …vo1.02.09p the latest ? or should i have in it the vo1.01.35
thanks for the help
You didn’t say what model of Clip you have. I’m assuming it’s the Clip+, although there is also the Clip (original) and Cip Zip models.
On the Clip+, go to Settings > System Settings > Reset Factory Settings > Yes. Note all options are not visible in the little screen on the player. You will have to scroll (up or down) to find and select all options.
Note also this is different from a regular (and frequently talked about) reset. This is where you hold down the power button for 20-30 seconds, release, then restart. This is a main system reset, and can/should be used if the player ever freezes up or fails to respond to button presses, or otherwise acts wonky.
Resetting the “Factory Settings” changes your personal settings and the USB mode back to the way it was when it came from the factory. This is why (and how) you can change the Region settings. After doing this, you will also have to reapply your personal settings, like Backlight, power save mode, sleep timer, FM presets and the like.
 Good for you! If you have the Clip+ model, the latest firmware is 01.02.16. You can find it here:
http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/Sansa-Clip-Firmware-Update-01-02-16/m-p/150227/highlight/true#M31277
V01.02.09 is also for the Clip+, but is an older fw version. I would update to the .16 release, manually applying it following the directions in the linked-to post.
V01.01.35 is for the original (hardware version 1) Clip, a different model and will not work if you have a Clip+ or Zip.
:smiley:
more problems…now i think i have got the wrong FW in the player…
it will not let me do carnt do a fatory reset on the player in the menu…
the updater software dont work on my windows 7 so thats no good…
ive put music on the player in alburms and you carnt find them in the player menu no matter where you look :(…
i think im sending it back …ant spending any more time on this…
Impossible. The player will only accept the firmware desgned for that particular model. You cannot install the wrong firmware on it, even if you wanted to.
In youy last post, things seemed to be working OK, what happened?
Don’t use the Updater. It will only update the firmware. If you have the latest, but there’s a corruption problem or other reason you want to re-apply in the firmware, it won’t work. That’s why I advised manually installing it.
Do you have an “Unknown” artist in the Muisc menu? If you select this, is your ‘missing’ music there? Thses things sort and display the infirmation contained in the ID3 tags of the music files. If your music doesn’t have tags, or they are the wrong format, etc. it doesn’t know what to do with the information it cannot read, so lumps it together under an “Unknown” heading.
Have you read the User’s Guide? It will explain and instruct you on many of the basic function of these players.
ok mate thanks for the help …
hee is wat i did first i put the FW on the player by way of just draging it …the FW i put on lol was vol1.01.35 and that gave me the higyh volume :)…then i check and see that i thinks i put the rong one on lol …
so i looks again and askes you …you told me where go and i have now put the one on what you siad is the latest vo1.02.16p
and its seems ok now…
i set it all up and everythink is working ok bar its sometimes hard to find mp3 alburms ive just put on it …
got a 8 gig card in it as well so its now 16gb :slight_smile:
so looks like ive dune it just got play around a bit more with it to get used to it lol …
anyways thanks again for the help …an as alwasy have a nice day :slight_smile:
the format i put on first was some mpeg layer3 mp3 winamp filel…there still on there but carnt seem to delete them lol even if i delete the music follder and make a noth one in windows there still there on the player :confounded:…may try deleting them with the player not the pc next time my work…
files im puting on now are all in mp3
Sansa clip + 8gb is the player
dreww wrote:
the format i put on first was some mpeg-4 lol…there still on there but carnt delet them lol or find them…my try deleting them with the player not the pc next time…files im puting on now are all in mp3
Well, there’s your problem, or at least part of it. MP4 is a multimedia format and is not supported on the Clip+. Maybe those are the ones with the lyric embedded. Youy’ll have to find those and remove them. I wouldn’t try doing it on the player though, they’re likely to freeze it up.
Connect your player to your computer and navigate to the Music folder/directory on the player in Windows Explorer. Then do a Search for *.mp4. This should return all files with this file extension so you can delete them. :wink:
Sorry i got the files rong that i carnt find an delet …they are mpeg layer3 mp3 winamp file
god now i carnt get the player to conecet to the pc lol …? wouldent be cuz i took the player updater out the pc??
got go find that now an install it again lol …
tryes to conect but then go’s back off lol all the time now …:frowning:
i have big problems now with geting the player to sink with the computer…
tryed all sorts an it trys and then switchs off and just keeps doing it over an over…
its a usb driver problem…and i carnt seem to find a driver for it …windows carnt find one :frowning:
doing my head in now …i never had all this ■■■■ with my creative muvo …that worked right out the box…
well if i carnt get it to work its no good ill send it back.
:frowning:
update …well ive been trying all night to get the clip to sync with computer and it will not …
tred everythink i can think of and it looks as if the player is knackerd big time …all that hapens is it trys to sync with pc then off …
what comes up saying on the pc when i plug it in is …usb device is not reconized and has malfunctioned windows does not reonize it …:frowning:
ill try send it back and get my money back an get somert else…
thing is it will not even charge up now lol…so its no good for the bin …
well i got up today and siad to my self befor i email where i got the player from ill just try it again on the computer…
well it worked this time lol so i maniged to put about 20 pluss mp3 alburms on the player…
but the thing is the player was disconnecting most of the time from the computer…
i dont no if its maybe becouse the player is fully charged or what…anyway im playing it now and going to try run the battery down some …then try again in the computer and hope…
so the player is ok just got problems with the computer side now…
maybe a plugin the wall charger is the way to go? or dose it not connect to the PC when fully charged ???
