2TB Passport Wireless Pro shows 3.6tb free
How this Can be possible?
Hi @Raul2112 - do you currently have any other USB storage devices attached to your My Passport Wireless Pro?
And, can you please advise of the current firmware version of your My Passport Wireless Pro?
Storage capacity from the external USB storage or SD cards attached are counted towards the total capacity that the MPWP has access to.
I am seeing exactly the same bug with NO other devices (USB/SD) attached.
FW is My Passport Wireless Pro v1.03.04
This was not the case with the factory shipped firmware (which I can’t see anymore) so this bug is a regression.
Thanks
Had same problem after firmware update on new unit. Did a System only reset. Didn’t wipe any data but did fix the storage remaining counter. Very happy with this unit.
