I am unable to save files onto a new 8-gig Cruzer Blade. This was after I run the Sandisk Secure Access. If I try using it on any other computer apart from the one on which I run the Sandisk Secure Access, the password is rejected as being incorrect. I am unable to use the drive. How can I uninstall the Sandisk Secure Access or remove the password? Please help!
“How can I uninstall the Sandisk Secure Access”
Delete the SecureAccess folders and files. It doesn’t get installed so there is no uninstall to do.
FWIW I suspect there is a difference in the keyboards of the pc’s your using.
