hi,
i was uploading some picture when suddenly i cant connect to the wireless stick. upon putting into the PC, it says drive is corrupted. thus i did chkdsk /x/f and it has been running for a week but still going. my drive is 256GB
pls advise.
hi,
pls advise.
sounds like it may be a bad drive. contact sandisk support to check the warranty status.
I guess I can forget about it because i can’t remember if I register for warranty or not. Lol
you dont have to register for warranty. its still worth contacting sandisk support.
OK will do. Thanks for the recommendation
