Where may I locate the Firmware Updater for my SanDisk Extreme Portable 4TB (SDSSDE61-4T00)
I am trying to use the firmware updater on my SanDisk Extreme Portable 4TB (SDSSDE61-4T00) that I installed from this article to upgrade the firmware of my drive: SanDisk Extreme Portable SSD V2, SanDisk Extreme Pro Portable SSD V2, and WD My Passport SSD External Drive Firmware Update for Windows
When I run the SanDisk_Extreme_Portable_and_Pro_SSD_V2_Firmware_Updater.exe file, it gives the error message “No compatible device found”
The article says that when this error message is spit out, it means I am using the incorrect updater. Since this is the case, where may I locate the correct updater?
Hi @S3RENI7Y
You have to use their software. Download sandisk dashboard
Also looking for SanDisk Extreme firmware. Why is it so hidden?
Has anyone been able to find the firmware update? I’m facing the same issue—my SSD remains idle whenever I try to access it, which is frustrating.
Has anyone considered legal action regarding this issue? If so, I’d be interested in discussing potential next steps.
Model: Extreme Portable SSD SDSSDE61-4T00 (4TB)
Looking forward to any insights.
