Where is the serial number on an extreme portable ssd 500
There was no sticker on my SSD purchased from Amazon Canada fulfilled by Amazon, supplied by Electron  SH which has a good reputation on Amazon but no Internet presence.  There is printing grey on black on the back of the device which is difficult to impossible to read even with a magnifying glass. The packaging looks legitimate.  How do I find the serial number?
its on the back of the drive BUT your going to need a magnifying glass to see it its not printed very well
You can also find the serial number on the packet in which the SSD was packed.
Apart from that, I believe that the serial number is also printed on the invoice of your product.
I hope this helps!
Regards.
Ruskin
Apps4Rent
Navigate to the folder containing the images you want to transfer. Select your preferred pictures. Right-click the selected images and highlight the “Send to” option. Select the “Removable Disk” option to automatically transfer the pictures to the storage device…   the cinderella solution reviews
