A brief question: What is the small metal ring that protrudes form the top top of my new Cruzer 16Gb “micro” flash? what might it be used for?
Thanks for your advice.
– Roberts G. “Gary” Stevenson
Hi Gary,
Dear member of SanDisk Community, welcome.
Mmm … I think you mean the new Cruzer U , (it’s very beautiful…).
Check out these links: http://www.sandisk.com/products/usb/drives/
http://www.sandisk.com/products/usb/drives/cruzer-u/
http://www.sandisk.com/Assets/docs/Cruzer_U_data_sheet.pdf
Enjoy!!
Regards, Alfred. (Google translated)
Thanks, Alfred, for your timely reply:
I misidentified my new USB drive. It is the CRUZER FIT USB FLASH drive. I have four of them.
Sticking out of the top of each, away form the connecter pins, is a very small metal tab with a hole pierced through. It looks like I can stick a piece of fishing line the hole and make a loop to put it on a key ring. Is that what it’s for? Or is the tab for write protection.
This is NOT a critical issue.
Hi Gary,
Yes, for make a loop to put it on a key ring.
Not exist on the pendrives, a tab for write protection.
Link: http://www.sandisk.com/products/usb/drives/cruzer-fit/
Enjoy!!
Regards,Alfred. (Google Translated)
Hi Gary,
Yes, is for make a loop to put it on a key ring.
Enjoy!!
Regards, Alfred. (Google Translated)
Hi Gary,
Enjoy!!
Aahh . . . Thanks, Alfred – Gary
:smileyvery-happy: Ok!! Enjoy!!!
