I was using SDHC cards on rPi, and I am tired of burning cards every 6 months. So, I was advised to buy MMC, but I wanted to be sure they are better than SD. And I found this page.
So, in emergency, I have bought an eMMC card plus the micro SD adapter on Amazon. Now, I am still looking for wear leveling in SD cards. For now, I have found various contradictory peaces of information. For SD and SDHC, each manufacturer was free to do any mess; it’s said (but I have not found any proof yet) that SDXC implies WL.
Out of those OEM-industrial cards (which are not supported by the official chat room), using any standard end user Sandisk card ( https://www.sandisk.fr/home/memory-cards ) in an rPi breaks the waranty. Still, for booting an rPi, they recommend the High Endurance stream (which is also called video surveillance https://www.sandisk.fr/home/memory-cards/microsd-cards/high-endurance-microsd ). Both are SDXC white-white; but the industrial has the word industrial written on it.
I was said that eMMC probably includes a better WL algorythm than any micro SD card. I can’t proof check it.
Here is what I have been said by the Sandisk support chat:
all Sandisk cards do WL; but knowing which WL algorythm is used is an industrial secret. Ultra cards do it, even if it’s not mentionned on the product page (it’s officially written on the Extreme page).
any end-user card inserted in an rPi looses it’s waranty
when you have an rPi, and want to insert some stuff in the SD hole, it’s recommended to choose a High Endurance model (also called video-surveillance) https://www.sandisk.fr/home/memory-cards/microsd-cards/high-endurance-microsd . They are very similar to industrial cards, except they don’t have the INDUSTRIAL word.
all modern flash devices have wear leveling. The cards you have been using however are not designed to the type of work load a pi will put on the card. sandisk supports recommendation of the high endurance cards is correct if you are looking at retail lines of cards. you could also use industrial cards as well but any support would be though the distributor where you purchased the card not sandisk retail support.
