most all flash memory is MLC based now. all flash memory will have wear leveling but endurance is very workload driven. the best suggestion for you would be to contact an OEM distributor. they will likely have some questions regarding the workload and would be able to suggest a product line that fits your needs. from the link below select your region and OEM distributor.
