WD sync wont sync some folders
Does anybody have a problem whit wd sync after windows updates.
Last two months some folders doesn’t sync. On mac works everything OK.
I try to reinstall but its the same problem.
Any help?
Regards
Perhaps the following article will be able to assist:
https://support.wdc.com/knowledgebase/answer.aspx?ID=19492
