Hey there,
I successfully bought a new WD My Cloud not only because of the WD Sync feature. I installed the software on my Macbook running the latest macOS but when I try to select a local folder to sync from, some folders are blurred out. Even the normal looking folders can’t be selected. I attached a photo of my problem. What am I doing wrong or is this just an software issue with macOS High Sierra?
Thanks for your help!
