Hello, i got the activation code in the email but none of the links work.If someone can give me the link where i can use the code would be much apreciated.Ty.
Open up your SmartWare and look near the top right and see if there is a gold key or gold like calendar icon. If there is click on it and see if the box comes up to activate to pro.
See the User Manual, Upgrading to the WD SmartWare Pro Software.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705057.pdf
Posted by,
cat0w (USA)
Ive tried as you said but there is no golden, upgrade thingy anywhere, i looked in all options and corners.Also tried the manual, no luck with that either.I get no window for upgrading to Pro.What exactly does Pro adds ? maybe i can live without it.
Read the information provided in the Learning Center. Use the following link.
http://www.wdc.com/global/products/features/?id=1&language=en
When you open SmartWare and click on the Help tab what product and version is showing in the bottom left. Read the last sentence in the image below under WD SmartWare software.
Posted by,
cat0w (USA)
