Upgrading to Smartware Pro problem
I have Windows 7 Pro, bought a Passport Ultra, which gets an upgrade to Pro included with purchase of the drive.  When I installed the software on the drive, Smartware version 2.4.12 which is basic, not Pro that loaded.  The software requires an activation code.  How do I get my code?  Am I not seeing an upgrade location other than the upper right corner of screen.
As a recommendation, contact WD Support for direct assistance on this case.
WD Contact info:
http://support.wdc.com/country/index.asp?lang=en%22
I have got exactly the same problem - bought my passport ultra with smartware pro version included, but I am unable to activate it to Pro version - no pop up windows to register an email address to receive activation codes. Have already contacted support, opened a case but got no response.
the same with WD My Cloud… Solution will be appreciated.
