Is there a way to use Smartware to run a scheduled unattended backup from more than one source drive? I have two WD external drives, and I want to back up my internal hard “C:” drive and one of the external ones to the second external one, and have this run on automatic backup overnight. I don’t see where I can select more than one source drive at a time.
At this moment WD SmartWare is optimized to work with internal disk drive sources, and external sources may not be able to add additional files at once. If possible, then it will be available using the “File Backup” enigne as opposed to the “Category Backup” engine.
I would recommend creating an Idea or add your vote into an existing one in order to increase awareness of this feature.
