I’m facing a problem since almost 3months, the problem was caused because of a PDF file that I force it to be send to the hard disk. it says it’s Raw and I used couple of softwares but still the partitions are not together and I cant combine them to reach the data. is there is any way to reach the data without format it because i’m not sure how much from the data I will get back if I format it, here is a photo from the drive manger.
It seems that the drive is in RAW file system, in order to extract the data that was stored on this drive you have to contact data recovery partners, however if you wish to use the drive again, you can format the drive in any of the file systems that your OS supports, like NTFS, exFAT etc, to format the drive please visit the link mention below and follow the steps:-
►it is not possible if you format the drive and afterword you wish to recover the data from it.
