Ok so i had WD problem(WD My Passport Ultra 1tb)
so i have been told to Delete Volume And Earse The Drive and now my drive went RAW
i dont know how to fix it please help
Have you tried formatting the drive?
A post was split to a new topic: Nadav_Grossman - Repeated posts
i did
some “fatel errors” showed up
Hi Nadav.
I have the same problem (Raw Drive).
can you please update me how you succeed solving the it?
Thanks!
Once the drive turns into RAW, you’ll not be able to access RAW partition or drives & neither able to access your computer. Common fixes include formatting RAW hard drives but it involves the risk of permanent deletion of your data. If you wish to recover your data from a RAW hard drive then you need the help of reliable data recovery software.
To know more about RAW Data Recovery, here I suggest you to check out the below article link:
What is RAW Recovery and How to Recover Data from Raw Drive?
Hope this will help.
Have you tried to format it again and change the RAW file system to a recognizable file system? If you have deleted the volume, it should be an unallocated space, which can be used to create a new partition with a normal file system. If both do not work, you can check if there are some bad sectors on the WD to fix RAW drive.
