WD MyPassport Wireless for Android 7.0
Hello, new MyPassport Wireless user here. I’m having trouble connecting my MPW to my Samsung A5 2017, running on Android 7.0. I can detect the device and connect to its network, but when I try to connect to the device using the MyCloud app, it just says "Unable to access the My Passport Wireless. Check your mobile device’s Wi-Fi settings and make sure you are connected to the My Passport Wireless network. (1004). At first I thought the device had a problem, but I downloaded the MyCloud app on a friend’s iPhone and it connected without any problems. Is the MPW incompatible with Android 7.0 phones? Many thanks in advance.
Hello pren_o,
MyPassport Wireless device is compatible to be used with Android 7.0 devices.
Please update the firmware on your My Passport Wireless to the latest version (1.07.02) . Software and Firmware Downloads | WD Support
If issue persists try to reset the MPW device and try to connect it once again
