WD MyPassport Wireless
I would like to know if the WD MyPassport Wireless (1 TB) is also compatible with Iphone and ITablet.
It is compatible with iOS devices, and Android devices be they phones, or tablets.  Read all about the MPW at wdc.com
My android phone won’t connect the my passport WiFi in my wifi settings list so I cannot use the my cloud app, can you help?
I suggest you get in touch with WD support by phone. They can help you with this in real time.
Thank you, will do.:slight_smile:
