WD My Passport Ultra causing BSOD
I was copying some files to my My Passport Ultra one night and I got an error while the files were copying.
Next thing I know my hard drive wont show up on my laptop anymore. And furthermore, when I remove the USB connection, my laptop gets a BSOD.
The LED does light up on the HD but its a constant rate blinking.
What’s the issue here? Can it be fixed?
Hi niankaki,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
