So ive had this hard drive for a couple months now and today it just doesnt want to connect to my desktop. When i plug it in it spins and lights up like usual but it is not found on my computer. I havn’t dropped it or unplugged it unproperly. Also when i connect it to my laptop it works perfectly and everything is still there. I even formatted it and it still wont connect to my desktop. Any suggestions would be much appreciated.
This case sounds like a driver issue or a letter issue.
How is the drive showing on disk management?
Check the links below.
How to access Disk Management in Windows XP, Vista, 7 or 8 to manage hard drives
thank you so much i followed the second links instructions and after unplugging my computer and restarting it it seemed to have fixed my issue.
Glad to hear that.
You can select that post as a accepted solution so other users can identify what post was helpful.
