hello,
need help please our XP computer has crashed, now we only have win 7 machines
how do we access our backed up files from your external drive
also what hoops must we go through to get tecnical help via e/mail?
thank you
len brauer
hello,
thank you
len brauer
Hi lensgarden, what backup program did you used to backup your files, if you used Smartware check the link below for the steps.
How to retrieve a backup using WD SmartWare Version 1.6.x and earlier
Service & Support
http://support.wd.com/contact/index.asp?lang=en
all i did was drag and drop the files from the xp hdd to the wd drive
i did do and initial back up as per the wd instructions but we donât want that bit
tried that support page all it did was run me around in circles?
len
i tried support by e/mail thingy and got this :
| Â | Â |
what do they want why canât they simply accept my post?
what is it with wd? i want help not stumbling blocks
why donât they contact me then
i need help please i cannot contact you
Hi again, if you dragged and dropped your files into the external hard drive, you should be able to connect it to the Windows 7 PC and copy the files to the PC. If the external hard drive is not recognized, try using a different USB cable, avoid USB extension cables or USB hubs.Â
thank you,
we will try again today and let you know.
will the drive be any use to us for back up from win7?
sorry feeling like a nuisance right about now, but we plugged it to both our machines now both with win7, it does not even show that we connected any sort of hardware, on both machines we have âCâ drive and the ROM drive
our very 1st back up we used the WD program to do a system back up
still need help
You can check on the disk management window to see if the hard drive is recognised there. If the hard drive is still not recognized and you have already tried replacing the USB cables, it would unfortunately appear to be faulty. You can contact support to replace it.Â
we are a little naive with the technology, where do we find âthe disk management windowâ?
many thanks will contact the link provided
went to that link, but donât seem to be able to post anything, this drive may be out of warranty, we bought it 2007 or 2009, canât be sure.
we really need to be able to resurect our backed up data or all is lost.
many thanks
Sorry for that, lets see what we can do. Click on the following link for the steps to open the disk management window.Â
How to access Disk Management in Windows XP, Vista, 7 or 8 to manage hard drives
WIN7 still does not recognise the WD elements disk
thank you
Sorry to hear that. If you need to recover your files you can contact any of the data recovery partners on the WD support page, some of them offer a free evaluations of your drive. Chick on the following link for more details.
so we can be sure now that the drive has failed?
we didnât get much use out of for $135AUD we paid for it
we will contact the data recovery people in west end, so no doubt we will have to pay post or freight.
to date thank you for perservering with us
will be in touch
hello maybe for the last time?
you have been as helpfull as you can i would say
that we now canât see any satisfaction in external drives, amybe we stick to flash sticks? lot cheaper.
estimate from data recovery centre incâ P&P:
was between; $600AUD and $1500AUD.
way out side what we could afford, we will see a local bloke he maybe able to help, pity there isnât a reliable disk recovery software program for home users.
so to date the $135AUD we paid for the drive is a loss
but thank you all the same for your patience
