Every time I plug in my external hard drive my pc can recognize but is unable to load it and it crashes the file explorer. and turns my background black. When the background is black I am unable to access anything until I unplug the external hard drive. None of the crazy stuff happens until I 1. turn off then turn back on my pc 2. is clicked on in file explorer. Please help.
Whenever you connect an external drive to your mac, the storage drive may not show up on Desktop, Finder, or even on Disk Utility due to various reasons:
USB connectivity problem
macOS preference settings
Partition map damage
Device incompatibility
Physical damage on a drive
However, to fix the issue, you can try the below methods:
Check the USB connectivity
Enable visibility of external hard drive
Update macOS
Repair external hard drive by using Disk Utility
Repair external hard drive by using Terminal
Erase the external hard drive
If none of the above works, then the drive needs replacement
Further, you can also check the below link for steps to be followed in each method mentioned above:
