TOTAL GARBAGE !
Buyer be aware, don’t buy it !
TOTAL GARBAGE !
Welcome to the WD Community.
Sorry to see how you feel about the product.
Can you please provide more information about your case. Perhaps, some of the users on the community might be able to help you.
Even i feel the same About WD … The problem is with my WD Element 1 TB it stops responding suddenly then i unplug it then replug it to the USB port then i cant see the partition its being detected by device manager and in disk management too but as uninitialized and unallocated unknown partition and when i try to initialize it says "Process cant be completed due to I/O Error " i tried changing cable tried it on diffent PC’s but no luck … Any help will be much appriciated cause the data is important RMA is not the option
