I’ve purchased my WD Elements couple of days ago and it worked fine. Yesterday, when I was transfering some data on it, everything freezed, so I had to pull USB cable out.
After that WD Elements is not recognized on any of my PC-s…and in Disk Management it says ‘Not Initialized’. When I try to initialize it it says : ‘The system cannot find the file specified’.
I see on google search that this was the common problem in 2011/2012, but I could not find the solution for it…
Hope you can help. I also contacted official WD support by e-mail, still waiting for the response.
Best regards.
