I’ve tried the following, and USB transfers are still horribly slow. I’m running Win7Pro 64-bit.
Plug drive into back USB port, not a hub.
Turn of search indexing temporarily.
Disable Superfetch and Remote Differential Compression.
Run these commands:
netsh int tcp set heuristics disabled
netsh int tcp set global autotuninglevel=disabled
Device Manager > Elements Drive > Properties > Policies > Better Performance.
Turn off Background Intelligent Transfer Service
Move USB keyboard to a different bus than the Elements drive.
Tried copying files to the drive from four Linux distributions (Mint 13, 15, 16, Xubuntu). Speeds were still awful - started at 15-20 MB/s and within 15 seconds slowed to under 200 KB/s.
Checked Device Manager power and speed settings for the Elements drive and USB hubs. All are high speed and 500 mA.
If you Google “WD Elements slow,” you’ll find that the problem goes back more than 4 years, with no full-coverage solution offered by WD, Microsoft, or seemingly, any independent techies on forums. If I don’t find a solution soon, the drive will go back to Fry’s.
