I have the following problem with my external hard drive. It is a model ‘My Passport Essential SE 750 GB USB 2.0/3.0’.
P/N: [Deleted]
Model: WDBACX7500ABK-00
Always it has worked correctly, but from yesterday when I connect it to a PC or Laptop pops a message “WD BAD PCB USB Device” and “WD Ses USB Device”, then request install the driver, but it doen’t recognition the Driver. (II have instaled the last ‘WD SmartWare 1.6.2 and WD Ses Driver’)
When I go to Windows Storage Disk Management, the device doesn’t appear.
I have used the Victoria Software and the Device been showed and the follow information:
Model: WD BAD PCB;
Capacity: 1 LBAs
Firmware: 0000
Disk Size: 1LBAs 0kb
CHS: 0/0/0
Features: Not ATA
Sector: 512 Byte Revice it!
[Warning] Invalid drive geometry!
But I don’t know use this software.
Also, the UVCView Software showed:
---===>Device Information<===---
English product name: "BAD PCB"
ConnectionStatus:
Current Config Value: 0x01 -> Device Bus Speed: High
Device Address: 0x02
Open Pipes: 2
===>Endpoint Descriptor<===
bLength: 0x07
bDescriptorType: 0x05
bEndpointAddress: 0x84 -> Direction: IN - EndpointID: 4
bmAttributes: 0x02 -> Bulk Transfer Type
wMaxPacketSize: 0x0200 = 0x200 max bytes
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x03 -> Direction: OUT - EndpointID: 3
bInterval: 0x00
===>Device Descriptor<===
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0210
bDeviceClass: 0x00 -> This is an Interface Class Defined Device
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40 = (64) Bytes
idVendor: 0x1058 = Western Digital Technologies, Inc.
idProduct: 0x0000
bcdDevice: 0x1008
iManufacturer: 0x01
English (United States) "WD"
iProduct: 0x02
English (United States) "BAD PCB"
iSerialNumber: 0x03
English (United States) "0671E8D00671E9F2"
bNumConfigurations: 0x01
===>Configuration Descriptor<===
bLength: 0x09
bDescriptorType: 0x02
wTotalLength: 0x0020 -> Validated
bNumInterfaces: 0x01
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0x80 -> Bus Powered
MaxPower: 0xFA = 500 mA
===>Interface Descriptor<===
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x02
bInterfaceClass: 0x08 -> This is a Mass Storage USB Device Interface Class
bInterfaceSubClass: 0x06
bInterfaceProtocol: 0x50
iInterface: 0x00
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x00
Appreciate any help to assist me recover the possible amount of data I can.
Thank you in advance.
