Hi, I just installed my WD passport drive with the WD Backup application. When I start the WD Backup application, when I want to add a new backup plan, the only files I can select are those present on the 2 partitions (C and D) of my local hard drive.
WD Backup does not see the different remote drives connected to my computer via the network.
Is there any procedure to follow to be able to backup files which are located on remote drives throught an internal network ?
Thank you in advance for your help.
Best regards.
Unfortunately, this software does not recognize network drives as backup source.
what a pity, is it planed to enhance the software with this interesting capability in a new release ?
Thank you in advance for your reply.
Best regards.
Thierry CONVARD
Message du 10/05/17 21:52
Copie à :
G_Rayn
May 10
