I have an extreme 16 gb sdhc card (30mb/s’) and after inserting it in a pc in an internet cafe in Vietnam, it picked up a virus. 18 months ago, I picked up a virus in Tunisia with another memory card, and sorted it out myself (the virus caused the files to be hidden, so I just went in to tthe folder menu and un-hid them). That was easy to figure out.
However, this latest virus is not that easy to sort out. I’ve looked at various forums and youtube, but I’m not 100% confident of sorting out the problem.
Ideally, I’d like to find a solution that’s ■■■■■-proof, and as someone with average commonsense, I should be able to follow detailed instructions.
As I travel a lot, I’d like to educate myself on these sort of problems, just in case it happens again. So, is there something out there that I can use to fix the problem, plus it’ll help me in the future, should another problem arise.
Also, is there a product out there that I can insert the memory card into, then plug that whatever-it-is into the pc/laptop, and if there is a virus, then the whatever-it-is will stop it from reaching the memory card.
Many thanks.
