[v0.6] video4fuze
This program works great for me. I’m using Vista SP2. I’ve only converted a couple of small vids so far (3-4 minutes long), but I was able to convert the mp4 videos that the Sansa Media Converter 2 program wouldn’t touch with no problem.
I do get the error message everytime I use the program, although there’s no problem with the videos playing.
Font config error: cannot load default config file
Thanks!
Thanks!
That’s a really weird error, and even weirder if you’re using windows. (a quick google search shows that it’s something related to a missing font.conf files for a X server…)
@ssorgatem wrote:
version 0.6 is out!
The deb package depends on python-qt4 (>= 4.5), while debian lenny has only 4.4.2-4. I installed it with the --force-all switch and it seems to work fine. However, aptitude now gives me a warning on video4fuze and its dependencys on every upgrade.
Is there a reason, why v4f depends on  python-qt4 (>= 4.5)? If not, could change it to the old value?
struct
somewhere between 0.5 and 0.6 it stopped working in qt =< 4.4, but I may have reverted something that broke it on qt 4.4… It definitely won’t work in qt 4.3, that’s for sure.
If the aptitude warnings annoy you, youc an also repackage it:
  • extract the deb package with your favourite archiver and you’ll have a folder probably named “video4fuze-0.6_all” with two subfolders:  DEBIAN and usr.
  • edit the file DEBIAN/control, and change “python-qt4 (>=4.5)” to “python-qt4”.
  • Now, from the directory where you extracted the deb, do (assuming the folders “DEBIAN” and “usr” are inside “video4fuze-0.6_all”)
  “dpkg --build video4fuze-0.6_all/ video4fuze-0.6+lessqt4depends_all.deb”
 And now you’ll have a new deb package, “video4fuze-0.6+lessqt4depends_all.deb”, which is exactly the same but wich won’t annoy you with warnings in aptitude.
That was easy. Thanks a lot.
struct
Thanks!
Huh. That’s weird. It shows up in the cmd box that pops up during conversion. It doesn’t seem to effect anything though, so I’ll just ignore it.
This program won’t damage my computer, will it? I used the Sansa Media Converter on my laptop before and it worked great for a while, but after a few days of having it installed, my laptop froze up and I had to shut it down with the power button; now it only works in Safe Mode. The other computer, which has a good anti-virus program on it, said the SMC is a virus. But Video4Fuze is safe, right?
Message Edited by shrinkingviolet on 05-25-2010 02:55 PM
Honestly, shrinkingviolet, it sounds to me like you have a problem with your computer—some computers have hardware flaws that manifest only when you do intensive stuff like video, leading to freezes or shutdowns.  I had a laptop like that several years ago, actually.  Needed to get it fixed.
I think someone would have complained about it if that would happen…
Yeah, I know SMC is evil and all that stuff, but I don’t thinkthat it actually damaged your computer… most likely, you got a virus in your computer by other means, which could then have infected SMC and also thrashed windows’ files…
Anyways, video4fuze is opensource, that means everyone can look at it’s source code and see what it exactly does,  and if it were dangerous or malicious, someone would have spotted it out and alerted averyone. So yes, you can consider it a lot safer than SMC or even your OS.
Well, I just think SMC is the cause of the problem since my desktop computer said there was a virus detected when I tried to install it there. Anyway, thanks for the info!
Do I need to download everything on the page linked to for it to work? I did, but whenever I click on any of them that aren’t the installer or the program (which is already installed on my computer), it says “Windows cannot open this file.” I’m using Windows Vista - is it supposed to work on that? Or am I just doing something wrong? I tried the software out and the video doesn’t show up on my player.
EDIT: Never mind - I just realized that the software doesn’t transfer the video to the player, so I need to copy and paste it myself. That’s why it didn’t show up. All right, I get it now. Thanks! It works!
Message Edited by shrinkingviolet on 05-25-2010 06:04 PM
One more question: Do I need to download everything listed on the page you linked to for it to work?
If you’re using windows, the installer contains everything it needs to run (that’s why it’s 17Mb when the other versions are less than 1Mb.
Download it, double-click on it, next, next, next, next and that’s it.
I was able to use this just fine before the upgrade.  I even uninstalled and started over.  Now, I get all sorts of errors and warnings.
error in mencoder:
can’t open files
device inaccessible
warning mv not available
I also get a pop-up error message that says there is an error in the mencoder and documents and settings.  It’s rather long and I couldn’t copy/paste it.
I’m not computer savvy, but I was able to get this to work beautifully last month.  I’m now a bit stuck and don’t understand all of the techy talk.  Please explain what I’m doing wrong, or if I missed something.
Mmm strange. Have you tested the portable version? (the download which is for windows but isn’t a installer: it’s an archive containing video4fuze, and you can extract it whereever you want and run video4fuze from there, whithout installing)
If it doesn’t work, erase  your video4fuze configuration file. Where it is? well, it depends on your OS… “$HOME/.config/ssorgatem productions/video4fuze.ini” in decent OSes, otherwise it’s somewhere under C:/Users/yourusername/Appdata or C:/Documents and settings/yourusername/ [google for the folder where application configuration is saved in your OS]
Read thru several threads and didn’t see, or missed, any info about video4fuze and how it works on Win 7, 64 bit machines.
Anyone care to comment on this?
Also, can it run in batch mode?  by this I mean convert the input video file to an output video file which I can copy to the Fuze later using Windows Explorer. The video formats I’m interested in converting are WMV, AVI, FLV, and MP4.   These are supported by the native Win 7 Home Premium using WMP.
Also, I’m assuming that the video4fuze download is GUI and contains everything needed on my Win 7, 64 bit machine.  Is this correct?
Musta missed it. 1st post in this thread:
Features
* .pla playlist creation and edition for MSC mode! ATM it’s a basic implementantion, but I might polish it a bit. These playlists can have files from both the internal memory and the µSD. Thanks to Dunny for providing me with all the information I needed about the .pla/.pla.refs file format :wink:
Video batch conversion capability, with advanced customizable options, and video thumbnail generation (.thm file) and huge input format support*
* Image batch conversion & resizing, in order to be displayable and fit the fuze’s screen size, with huge input format support
* Fully translated into 3 languages (english, spanish, catalan). If you would like your language supported, read the end of the post
* Crossplatform: works on all major platforms, taking native look and feel ( I don’t have a mac, so it’s not tested on macosx, but it should work. Also, it won’t take macosx’s look and feel if you use qt4-x11(fink, darwinports) instead of qt4-mac)
All those formats are supported (provided they are DRM-free).
Yes, if you download the installer or the portable archive, you’ll have all you need to run it. It’s compiled to 32-bit though, so it’ll run under WoW64 in win64 systems, meaning you won’t get all the performance you could from your machine (but if you’re using windows that means performance isn’t something you care much about, anyways).
Thanks SS.  I installed it and it went on fine.  Ran it and it created the new file in avi format.  Took me a while to figure out where the program put it though.  Haven’t yet moved the file to the Fuze.  The mp4 input file was 9 meg and the output avi file was 13 meg.  I thought that was strange considering the much lower resolution of the created file.
Mike
Mike
Yeah, the video format the fuze accepts is pretty crappy…
You can set the output folder to whatever you want (with the button “Output folder”)
I keep getting these messages when I try to convert a movie. I am using Windows 7 starter on a Asus Eee netbook.
[Window Title]
MEncoder
[Main Instruction]
MEncoder has stopped working
[Content]
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
[Close program]
Error
An error has ocurred: Command ‘[u’mencoder’, u’-msglevel’, u’all=0:statusline=5’, u’-ofps’, u’20’, u’-ovc’, u’lavc’, u’-lavcopts’, u’vcodec=mpeg4:vqscale=3:keyint=15’, u’-vf’, u’field,expand=:::::224/176,scale=224:176,harddup’, u’-srate’, u’44100’, u’-af’, u’resample=44100:0:1,format=s16le’, u’-oac’, u’mp3lame’, u’-lameopts’, u’cbr:br=128’, ‘F:\\video\\The\_Proposal\_PORT\_EN.wmv’, ‘-o’, ‘c:\\users\\tds\\appdata\\local\\temp\\The\_Proposal\_PORT\_EN.temp.avi’]’ returned non-zero exit status 255
OK
Gees, I’m blind as a bat!  That button was right there staring me in the face!
