At Least you got it installed in the First place… I had to download the software to install it initially then when I found out their was an upgrade My problems started… Can’t even access backup or anything else … very poor service …
Now, you dont have SmartWare installed on your system.
Rerun the Smartware update - you still dont have SmartWare installd (followed the guide, it said Rerun after install…)
As i still dont have SmartWare installed, i installed it AGAIN trough the USB HDD - guess what, stil the old version i´ve got.
Seemt to me, that the new version doesent work for Win 7 64…
Just not good enough WD - i have had lots of hassles with this drive now.
Had to void my warranty to fix the LLC problem
The drive makes my explorer.exe freeze, when i rightclick on a file, that i´m transfering to the USB HDD - my other USB HDD´s dont do this. They let me rightclick with no problem.
This, Smartware thing, can´t be updated.
Ffs WD… Come on!
Edit, my drive is the 2TB vers. with the WD20EADS drive in…
downloading, installing update, rerunning the update(Whats up with rerunning the update anyway?)
How did you re-run updates? From WD SmartWare Update button?
So, did new WD SmartWare get updated, but the issue is running the update again?
2. As i still dont have SmartWare installed, i installed it AGAIN trough the USB HDD - guess what, stil the old version i´ve got. Seemt to me, that the new version doesent work for Win 7 64…
Update gets only installed on your system drive and not to your external drive Virtual CD (VCD).
New WD SmartWare Software doesn’t replace old image on your VCD.
Also, you may want to make sure that you have all your Windows and .NET updates installed. You need to have .NET 3.5 installed or SmartWare may stop updating/installing.
