Using Hp Labtop, trying to set up San Disk to copy files. Unable to write vault structure, this program cannot continue, why ??
Hi @LCole,
To resolve the issue which your facing, please check mention below link:
Write Protect Error on USB Flash Drives
Link: Write Protect Error on USB Flash Drives
NOTE: If using a company computer, ensure your IT department does not block saving files to removable drives.
Hope it helps!!
Vault, in building construction, a structural member consisting of an arrangement of arches , usually forming a ceiling or roof. It exerts the same kind of thrust as the circular arch and must be buttressed along its entire length by heavy walls with limited openings. … How can you play like an expert with bitcoins?
you are not helping bud
