can the wireless stick tun on wireless once it’s pluged in and turn it off once it’s disconected
also as I understand you can use it as a backup device, but can you set up to offload everything off the drive to an andoid phone?
if the drive is connected to a PC it is mounted as a MSC (Mass Storage Class) device. When it is mounted as a MSC devcie the WiFi is disabled.
You can connect it to an AC charger and wifi will still work.
