Whenever I try to eject my hard drive via the icon in the system tray in Windows 7, I constantly get an error message saying that the device is currently in use and that I should close any progrmas or windows that might be using the device, and then try again. Does anyone know how I can fix this problem so that I may be able to safely eject my hard drive without running the risk of data loss? I also do not have WD SmartWare installed. Thanks for your help.
sh4d0w
