Hello there,
I have a My Book Essential of 1T.B … or better said, This :-
http://support.wdc.com/product/install.asp?groupid=120&lang=en
is the one I have.
My problem is that I can’t disconnect it normally and safely! Every time I do the right click and safely eject step, it tells me that I must close all running programs and try again later … I do so and keep just the normal programs like the antivirus & the Bluetooth running, but still I get the same message!
I could disconnect it by just removing the USB cable, but that may cause some problems in the future and make me lose data.
I need help to be able to disconnect the external normally with out closing all programs (sometimes I have important web pages open that am working on) or removing the USB cable.
Thanks in advance
