SanDisk Portable SSD Won't Eject
I’ve had my SanDisk Portable SSD for about a year. For the past few months, I’ve had a really annoying problem every time I try to safely remove the drive.
When I try to eject my SanDisk Portable SSD on Windows, I always get this error:
“This device is currently in use. Close any programs or windows that might be using the device, and then try again.”
But I don’t have any programs using the drive. I close everything, but the error still shows up.
@Martynow
(Get Support for Your SSDs and Flash Products | Sandisk)
Try this one.
  1. Use the system’s built-in Disk Management tool to force the release of the volume,
  2. Then safely eject the device in Safe Mode.
    Usually, the first step is sufficient.
This is a common issue. You can check out this link for a solution.
