- First of all, you have to download the iCareFone for WhatsApp Transfer app on your Mac or Windows PC from here.
- Once you download and install this application, you need to open it.
- Now select Whatsapp or Whatsapp Business.
- After that, you have to connect both your Android and iPhone to PC with the help of USB cable and Lightning port respectively. If you are currently transferring from android to iOS, then your source device will be android phone.
- And then connect the iOS device to the destination
- After that click on transfer
Readmore
Hello, I am providing some additional details to make the response more helpful for the community:
- Mention that users need to enable USB debugging on their Android devices and “Trust This Computer” on their iPhone for the transfer process to work.
- Remind users to create a backup of their WhatsApp chat history before starting the transfer to avoid any data loss.
- Explain that the iCareFone for WhatsApp Transfer app supports transferring not just text messages, but also images, videos, voice messages, and documents.
- Inform users that the app is compatible with the latest iOS and Android versions, but they should check the compatibility of their devices before proceeding.
Here’s a revised response incorporating these points:
To transfer WhatsApp chats between iOS and Android using iCareFone for WhatsApp Transfer, follow these steps:
- Download and install the iCareFone for WhatsApp Transfer app on your Mac or Windows PC from the official website.
- Open the application and select WhatsApp or WhatsApp Business.
- Enable USB debugging on your Android device and “Trust This Computer” on your iPhone.
- Connect both devices to your PC using their respective cables (USB for Android and Lightning for iPhone). Set your Android as the source device if transferring from Android to iOS.
- Create a backup of your WhatsApp chat history before starting the transfer to avoid data loss.
- Click on ‘Transfer’ and follow the on-screen instructions.
Note that iCareFone for WhatsApp Transfer supports transferring not only text messages, but also images, videos, voice messages, and documents. The app is compatible with the latest iOS and Android versions, but double-check your device compatibility before proceeding.
