Hello, I have problem with writing speed . I can’t get the speed over 250 M/s.
Motherboard:
"GIGABYTE GA-990FXA-UD5 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD "
Win 8 .
How to fix this problem ?
Motherboard:
Win 8 .
I have rthe same problem with my Ferrari
I can’t get it over 180 mph.
I have the same problem with my Ferrari . . .
Thanks you were helpful!
try using ATTO Disk benchmark and post the results. Crystal disk uses uncompressable data. Sandforce controllers do better with compressable data.
http://im40.gulfup.com/1bdsI.jpg
I think it’s good results ??
The problem was from CrystalDiskMark
thanks for help ^^
the results are good. the SSD is performing as expected.
Thank you very much for helping me .
