Yes, I’m getting the same thing. The work around provided makes no difference as I already have my power plan as High Performance. This ■■■■■ since it’s a brand new drive.
Same problem here. Long test fails every time (short works though). Stuck at 10% and then returns error code 15, which according to KB means that the drive has not updated the progress bar after 5 minutes (link). The workaround they suggest obviously does not work.
